help!! rs2 mk2 been stood for 15 years
Old Feb 9, 2009 | 04:31 PM
clutchitupson's Avatar
clutchitupson
Default help!! rs2 mk2 been stood for 15 years
ive just brought a mk2 rs2000 which has been stood for 15 years the car still has 4 star petrol in it need help regarding getting things up and running ie what to do regarding engine brakes all drives i dont want to brake anything heeeellllppppppppppp me
cheers steve
Old Feb 9, 2009 | 06:16 PM
Change oil, air filter oil filter plugs, drain fuel, strip down and clean carb replacing gaskets and diaphragms, renew fuel lines that are flexy pipe.
Drain coolant, refill with a/freeze, and new stat, new timing belt/tensioner, new tyres the list is endless, brakes.
You won't know full extent till you have a really good look, but the above is a minimum I would do.
Old Feb 9, 2009 | 07:58 PM
Tabetha has took the words out of my mouth.
Old Feb 9, 2009 | 08:02 PM
turbolee's Avatar
turbolee
good luck get cracking
RSmark84
Sep 13, 2015 01:29 PM
Adam Graham
Sep 6, 2015 06:04 AM
