Cossie 4x4 boost problem
Old Feb 5, 2009 | 05:18 PM
noel32's Avatar
noel32
Default Cossie 4x4 boost problem
Hi all,
I have a 1992 Sierra 4x4 cossie and she won't boost over 0.4 bar and that's with the actuator rod wound all the way in. i have replaced the actuator the amal valve the spark plugs the dizzy cap.I took the turbo off and sent it to a specialist and he said there was nothing wrong with it. Please please please can someone help me as I'm about to pull my hair out and i can't afford to lose any more hair.
Thanks all.
Old Feb 5, 2009 | 05:25 PM
LHD220Turbo's Avatar
LHD220Turbo
have you checked for air leaks?
what spec is the car please?
did it just all of a sudden start or happened over a period of time?
Old Feb 5, 2009 | 05:40 PM
noel32's Avatar
noel32
Thanks for the reply,
Have checked all the hoses no leaks whatsoever, she has full silicone hose kit,running dark green injectors, stage 3 chip, escort big turbo, also i have printout from pJ motor sport that she was running 342.6 BHP on 7 aug 2007. It strated giving probs about 4 weeks ago with no warning at all.
Old Feb 6, 2009 | 06:40 AM
Alvyn's Avatar
Alvyn
i/cooler leaking? or the penny ISN'T closing properly on the turbo?? at a guess!
Old Feb 6, 2009 | 04:55 PM
noel32's Avatar
noel32
Thanks it's not the turbo could be be the intercooler will check it out. Cheers
Old Feb 6, 2009 | 05:19 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
sounds like a wastegate issue imo
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Anutternutter
Aug 21, 2015 06:07 PM
RsS2daz
Aug 14, 2015 05:26 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
