ECU pinouts and IGN retards
Does any one have a pinout for the fiesta rs1800 ECU and the ignition retard pins. I know other ecu's has various pins to ground for countries with low octane fuel that will retart the ignition by a few degree's
Also how does the factory rev limiter work?, is it fuel or spark it kills and is it every other revolution of the crank etc.
Tried a web search but could not find anything usefull
CheeRS
Bri
CheeRS
Bri
I do not know the pinouts but there are at least two different types; one for external EDIS and the other for internal EDIS.
The rev limiter is via fuel cut. There are usually two stages; half fuel where every other injector firing is cut and no fuel where all fuel is cut.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
Sep 14, 2015 09:04 PM
bugger
