Xr3i Van conversion - HELP NEEDED!
Old Jan 30, 2009 | 09:05 PM
toms's Avatar
toms
Default Xr3i Van conversion - HELP NEEDED!
Have done most of the hard work, but the fuel tank for the xr3i wont fit the van, any suggestions?? Thinking about welding the swell pot from xr3i tank into the vans original diesel tank. Struggling to find a mk4 1.3 van petrol tank!
Old Jan 30, 2009 | 09:31 PM
siward's Avatar
siward
I'm having a simular problem, I am thinking about using an external swirl pot.
Si
Old Jan 30, 2009 | 09:42 PM
toms's Avatar
toms
Haven't heard of that on this job? How do you go about it?
Old Jan 30, 2009 | 09:44 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
keep the oe tank (clean it out)then use a lift pump to the inside of van then use a ext swirl pot and a rst pump
Old Jan 30, 2009 | 09:50 PM
toms's Avatar
toms
Can't i weld the swirl pot from the xr3i tank to the vans diesel tank?? Didn't know bout the method you explained - have you seen that done?
Old Jan 30, 2009 | 10:02 PM
tommytxr's Avatar
tommytxr
i had to do it this way when i had a rst van dont start tring to weld swril pots it to the diesel tank it piss easy to do ill pm u the bits you needif you want im tring to find out if the petrol van tank will work
Old Jan 30, 2009 | 10:11 PM
tommytxr's Avatar
tommytxr
have a look on ebay item number 330288477830 its a fuel tank from tha petrol van should fit n had a quick check up n i think its got a swril pump
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
stevierob
Aug 11, 2015 09:08 PM
S3an
Aug 11, 2015 07:26 PM
col93saphcos
Aug 7, 2015 03:21 PM
