Plzzzzz help
Old Jan 30, 2009 | 05:08 PM
rsvmad1's Avatar
rsvmad1
Default Plzzzzz help
Finally got insured 2day for the first time in 4 years, Still cant drive aarrr. The back lights on my mk4 escort van are playing up, when the lights are on the back left side go on but no break lights an when the lights are off the right side break light works, reverse light is fine. Any idea`s people?
Any help would be appriciated thanks again...
Old Jan 30, 2009 | 06:15 PM
rsvmad1's Avatar
rsvmad1
bump
Old Jan 30, 2009 | 06:25 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
its normally a earth problem, or may be a poor conection on the bulb holders
Old Jan 30, 2009 | 06:35 PM
rsvmad1's Avatar
rsvmad1
cheers m8 will take a look at the earths 2moz, do you think the indicator stalk could cause these probs as the lights on that too?
cheers pal
Oh, an the connections and bulb connections are all fine,,,,,
Old Jan 30, 2009 | 06:45 PM
Lloyd's Avatar
Lloyd
if the problem is the switch,then its a good idea to buy a new from a motor factors.
Old Jan 30, 2009 | 07:57 PM
st3v3's Avatar
st3v3
when ever ive had a problem with escort lights,its always been bad earths,bloody always been a problem..
Old Jan 30, 2009 | 08:22 PM
cabriolet's Avatar
cabriolet
earths earth earths
Old Jan 30, 2009 | 09:26 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
it will be bad earths it always is
Old Jan 31, 2009 | 09:27 AM
rsvmad1's Avatar
rsvmad1
cheers fella`s, theres an earth on each back light i no i can check. If its not them does any1 no if theres any anywere else that would affect the lights?
Tanks again
Old Jan 31, 2009 | 09:34 AM
t31ryt's Avatar
t31ryt
the browns the browns i tell ya
Old Jan 31, 2009 | 09:40 AM
rsvmad1's Avatar
rsvmad1
thanks pal, do ya no if theres an earth on the indicator/light stalk?
thanks mate
Old Jan 31, 2009 | 01:23 PM
The most effective cure is to hard wire it, or at the very least run a seperate earth from the body to each earth track on the light bulb fitting itself so bypassing the dreadfull connectors earth.
Old Jan 31, 2009 | 03:07 PM
rsvmad1's Avatar
rsvmad1
cheers m8, had a play with the earths! turns out it was themThanks people big help all working accept 1 break light, bought a new bulb an its not that so thinking bout running a seperate earth see if that does the job... hopefully will then am laughin
Thanks again people..........
rsturbo27
Jul 16, 2015 07:17 PM
rsturbo27
Jul 9, 2015 08:48 PM
sierramad
Dec 3, 2007 04:32 PM
