cvh efi engine.
Old Jan 29, 2009 | 09:07 PM
fordghiarsxrboy's Avatar
fordghiarsxrboy
Default cvh efi engine.
was just wonderin if any body knew if there were any differences with the efi mfi engines apart from the hole in the block for the crank sensor,and if any body out there was crazy enough to try to convert there mfi block to take a crank sensor as i've been offered a good mfi lump to replace my tired efi one.
Old Jan 30, 2009 | 06:20 PM
frsjon's Avatar
frsjon
the ports on the head are diffent shapes due to the injectors.. but if were just talking bottom ends then there nothing different that will cause a problem..the oil return stub in the block will be threaded but you can change that for the mfi one..(t3 turbo).... ... my fiesta rs turbo was running a s2 block for a couple of years... made a template of a efi block and drilled the mfi block... no probs..
Old Jan 30, 2009 | 09:39 PM
tommytxr's Avatar
tommytxr
why o why do i do it!!!!!
if you have still got a efi block work out the spacings on the efi block for the crank hole mark them on the mfi block n drill away you will need a tap aswell cant rember what size
mk3ste
Oct 17, 2021 10:09 AM
mondeomark
Sep 28, 2015 06:28 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
