compression ratio how do i work it out???
Old Nov 24, 2004 | 08:27 PM
jaypen's Avatar
jaypen
Default compression ratio how do i work it out???
adding forged pistons to my zetec turbo conversion,pistons come with "unfinished crowns" so need them machined to get a compression ratio of 8.1.1.
anyone out there that could help me calculate how i can arrive at this?
Old Nov 25, 2004 | 08:15 PM
escort mk1's Avatar
escort mk1
When the postion is at tdc aspace is left between its top and the end of the cylinder: the volume contained in this space is called the clearance volume. The volume enclosed above the piston at bdc consists of the clearance volume plus the swept volume and is called the total volume.
So you get
Compression ratio=Total volume divided by
Clearance volume
= Swept volume+Clearance volume divided by
Clearance volume
=Swept volume divided by
Clearance volume +1
Hope this helps you work out your compression ratio
Old Nov 26, 2004 | 07:28 PM
jaypen's Avatar
jaypen
cheeRS thanks for that m8
YODI
Aug 30, 2015 01:12 PM
155lee
Aug 14, 2015 11:21 AM
Zoggon
Aug 10, 2015 10:39 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
