no power to my abs
Old Nov 24, 2004 | 12:18 PM
bigal1978's Avatar
bigal1978
Default no power to my abs
hi i have no power to my abs motor/unit on my 2wd cossie
could any 1 tell me where the relays and fuses r 4 the abs thanks
Old Nov 24, 2004 | 01:19 PM
foreigneRS's Avatar
foreigneRS
Testing the future
the abs system on a 2wd cos has it's own loom separate to the main loom and fusebox. it does connect to the main loom though, to get power on ignition 1.
look behind the dash cover on the passenger side and you'll find the abs ecu there with the engine ecu. trace the rest of the loom from there, and you'll find a couple of, i think purple relays, and it should be bolted directly to the battery terminals.
Old Nov 24, 2004 | 05:46 PM
bigal1978's Avatar
bigal1978
found it thanks for replys fuse gone
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
