2.0 conversion, PATS help
Old Jan 22, 2009 | 04:04 PM
Mark_'s Avatar
Mark_
Default 2.0 conversion, PATS help
ive got hold of a p-reg mondeo which has a great engine but it has pats and i want to drop it into my 1998 escort gti
can i use a non pats ECU on it if i swap for a non pats loom and ECU?
if not can i swap the whole lot and use the 2.0 with the pats ECU loom and swap the chips in the key or swap the lock barrel?
if all of the above is wrong is there a way to disable the pats
or another way of doing it?
thanks for any advice given
Old Jan 23, 2009 | 08:35 AM
Cozziekid's Avatar
Cozziekid
You will need a Mk1 mondeo 2.0 ECU with the code DEEP, DESK or DEWY. Im sure you need to swap some terminals round on the multiplug too, theres a guide on what to change round somewhere, i'll have a search for it as i cant remember off hand where i've seen it.
**EDIT**
Found the site - http://www.sportingfords.com/forums/....php?f=16&t=95
Old Jan 23, 2009 | 05:08 PM
Mark_'s Avatar
Mark_
cheers mate
Old Apr 18, 2009 | 08:42 PM
blackgti's Avatar
blackgti
hi mar k i've also got an escort gti and was wondering how to go about fitting a 2ltr mondeo engine and what i would need to complete the conversion would be really gratefull for any info you might have or pick up along the way with your upgrade also keep me updated with your upgrade please mate cheers
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
SMILER258
Sep 28, 2015 09:04 AM
