Carb CVH Compression ratio
Old Jan 21, 2009 | 09:44 PM
jhot80's Avatar
jhot80
Default Carb CVH Compression ratio
Hi there,
Anyone got any idea as to what is the highest compression ratio a carb cvh engine can take using super unleaded.
cheers
james
Old Jan 22, 2009 | 10:41 AM
B16CVH's Avatar
B16CVH
Around the 10.5:1 mark should be ok, could go higher with better pistons etc...
Old Jan 22, 2009 | 01:48 PM
jhot80's Avatar
jhot80
yer thats about what i was thinking. got any guesses how much i would need to skim it by to get that if its a untouched head?
james
Old Jan 22, 2009 | 01:51 PM
B16CVH's Avatar
B16CVH
Ideally, you need to CC the combustion chambers and see what the value is, im guessing it is going to be around the 55cc mark. If you measure it you will be able to work out roughly how much to skim off. You will also need to know if the bores are standard and the thickness of the headgasket you are intending to use.
Old Jan 22, 2009 | 01:52 PM
jhot80's Avatar
jhot80
thanks for the help!
Old Jan 22, 2009 | 01:53 PM
B16CVH's Avatar
B16CVH
No probs, if you get stuck with the calcs give me a shout!
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
sridgett
Oct 1, 2015 07:30 PM
