Low Temperature reading
Old Nov 24, 2004 | 04:22 AM
mart2G's Avatar
mart2G
Default Low Temperature reading
I have a 1987 Sierra 1.6 Est. It has a SOHC engine. The Temperature gauge has started to read just below normal. I have been trying to sort out my heating system, changed thermostat, flushed system (several times!), I also had a leaking water pump...as a temporary fix for the leaky pump I put radweld in. I now know my matrix was the problem (I was trying to avoid taking it out if I could!) Havent replaced the matrix yet..All the pipes are hot..there is plenty of coolant (+Antifreeze) but now I am getting the low (sometimes it fluctuates) temp reading! I am wondering is it anything I have done? Or could it be the sender? I have investigated the electrical connections and they seem to be fine..is the temp gauge reading related to the heater matrix problem too? Please help if pos!!!
Martin.
Old Nov 26, 2004 | 10:39 PM
mk1_orion_boy's Avatar
mk1_orion_boy
Hi,
I had a prob like yours my temp gauge would never go up at all. I put a new thermostat in but still the same then put a temp sender and now it works sweet
Get a sender mate, think their under a fiver!
Old Nov 27, 2004 | 06:43 AM
dathers's Avatar
dathers
very low water level can read low on gauge,if the temp sender isnt imersed in water it will read much lower than the actual water temp.
Get that water pump changed before it seizes up,pops your cam belt off and bends all your valves,NOT cheap!
Dave
Old Nov 30, 2004 | 06:11 PM
mart2G's Avatar
mart2G
Cheers guys! I will grab myself a new sender! Gonna also get stuck into the water pump...i will be back to update! martin.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Tank Mike
Sep 26, 2015 08:07 AM
