I need a bolt ?
Old Jan 14, 2009 | 10:51 PM
RSLevi's Avatar
RSLevi
Question I need a bolt ?
HELLO every 1 i am just seeing if any 1 has a part i need 4 me standed turbo
its a bolt that screws on to the top of the turbo then the oil feed pipe screws on to that
sorry about not no'ing the name of the part i bin every were but no 1s got the part im after if any 1 has the part or no were i can get it from that would be great
thanks...
Old Jan 14, 2009 | 11:13 PM
siward's Avatar
siward
The part i think you are after is a 1/8 bsp to 3/8 bsp male adapter, I would double check the size or someone else might know? The thread that screws into the turbo is tapered. You can get them from www.lister.co.uk They are less than Ł2 each. Also i have seen them on ebay at Ł10 each :-(
Si
Old Jan 14, 2009 | 11:20 PM
RSLevi's Avatar
RSLevi
thanks alot m8 i got a bolt all ready what was 4 a cozzie turbo and were the oil feed pipe screws on to that bit is ok
its the bit that screw's into the top of the turbo just needs a little skim off i will check that site out tho
thanks.....
Old Jan 15, 2009 | 10:09 AM
You can also get these and all manner of fixings etc from Parkers.
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
little bram
Sep 27, 2015 07:45 AM
