Non starting RST
Old Jan 14, 2009 | 04:08 PM
rs milesy's Avatar
rs milesy
Unhappy Non starting RST
Finally got the series 1 back home after 12 months instorage, due to moving house again, The resto has been on going for 11 years, nearly got it started prior to it going in storage again, since then I have fitted a new fuel pump, changed the metering head 3 times, Replaced the battery, and it still wont start, I have fuel in the pipe to the injectors, it runs for a couple of seconds on the cold start, proved this by unpluging the cold start and it did not start, plug it back in and it runs for a couple of seconds, metering flap bounces when the engine cranks, gradually working my way through the supplementry workshop manual,but could with some inspiration Any ideas gratefully recieved.
Thanks
Old Jan 14, 2009 | 04:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like a air leak to me if your still MFi? Or ilde mixture is too lean but if you've tried 3 Metering units they cant all have been lean at idle. Maybe the wiring for the fuel pump has degraded and it's low on voltage giving you low fuel pressure?
Old Jan 14, 2009 | 05:37 PM
B16CVH's Avatar
B16CVH
How long has the fuel been in there?? Is there a good spark??
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
