running problem
Old Jan 12, 2009 | 03:20 AM
Hedley's Avatar
Hedley
Default running problem
when my car is warm or afta a quik blow about the revs keep dropping under 1000 rpm then it goes to cut out most of the time it does cut out but then starts sraight back up again any suggestions would be a great help to me thnx
Old Jan 12, 2009 | 07:00 AM
Make, model, mods, year, need more info.
Old Jan 12, 2009 | 12:16 PM
Hedley's Avatar
Hedley
Default spec
sorry lol i have a mk3 s1 rs turbo 1.6cvh pipercam mahle pistons uprated strengthed big end full 3" scorpion exhaust system bailey dump valve swirl pot blue samco hoses all around. its runnin a normal metering unit and is running at running in boost
Old Jan 12, 2009 | 12:27 PM
CO needs checking first, unless it just needs the idle speeding up a bit.
Old Jan 12, 2009 | 12:30 PM
antony215's Avatar
antony215
Escort Rs Turbo
Could be an air leak somewhere
Old Jan 12, 2009 | 12:39 PM
Hedley's Avatar
Hedley
sorry i might seem rewally thik but what do u mean by the co needs cheking first?
Old Jan 12, 2009 | 04:09 PM
The mixture, basically what comes out of the exhaust, needs checking to see if running lean, an air leak can also upset the car, but more likely to do all the time.
You are not thick, a thick person would not ask, the air and fuel need to be in precise ratio's to each other, this is what determines the end result of the burnt gasses CO, or carbon monoxide output.
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
