ERST S2 oil spray from dump valve
Hi guys,
My S2 RS Turbo is spraying a fine mist of oil out of the dump valve, I've checked the charge carrier pipe and there's a bit of oil in there too. I've had the turbo checked out and it's in excellent condition, no damaged oil seals, and it has a Bayleys breather system fitted, no pipes blocked up, so does anyone have any idea where it could be coming from?
Many thanks
Dave
Many thanks
Dave
Originally Posted by EssexBoyRacer
knackard piston rings at a guess.
Most rst's have a small amount of oil build up dont they??
Well everyone ive seen does and ive seen quite a few now mint ones and rebuilds.
