could a welded diff cause this???
Old Jan 2, 2009 | 04:16 PM
arseways steve's Avatar
arseways steve
Default could a welded diff cause this???
just welded the diff in my gls sierra, let the car off the lift, took it up the road, diff works fine but now the car pulls to the right big time, it drove nice and straight untill i welded it but why would the diff cause this.. any ideas greatfull...
Old Jan 3, 2009 | 09:20 AM
FlatheadFordV8's Avatar
FlatheadFordV8
The rear wheels are now locked together, and cannot turn at different speeds.
If one tyre is underinflated or has a lot less tread, then the rear will try to turn a corner all the time.
If you swap the rear wheels over, it should pull the other way.
Also check bushes on rear arms, as if there is a lot of play in them the rear can steer the car.
Also check front end, as it may have nothing to do with the diff work.
An LSD would have been a much better solution.
boeb
Jan 9, 2020 05:11 AM
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
