ib5 mix and match help !!!!
right i have a zetec-s
and i have a puma gearbox as the gear ratio's are shorter, but a longer final drive
so i want to swap the zetec-s final drive into the puma gearbox, and was wondering can i just swap the crown wheel or does the main shaft with the pinion need swapping too? cheers guys
