Interior light problem
Old Dec 28, 2008 | 06:54 PM
cossie04's Avatar
cossie04
Default Interior light problem
Interior light on my car has not been working recently. I had a look the other day, there is a red wire with a permanent live, a brown wire with a permanent earth, and a brown/white wire which i believe should have an earth when the door/s opened.
My problem is there is no earth when the door/s are opened, anybody know what might be causing this and how can i fix it??
Regards, Ed.
Old Dec 28, 2008 | 07:04 PM
burnzy's Avatar
burnzy
burnzy
Did it use to stay on for like 20sec's when u close the door when your ignition is off cos it could be the relay that is in the fuse box's that's knackered
Old Dec 28, 2008 | 08:23 PM
iansoutham's Avatar
iansoutham
OCD Victim
Unscrew the pin switch screws in the doors and retighten. They are the earth and can corrode quite easily.
See if that cures the problem for you
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
sridgett
15
Aug 3, 2015 07:26 PM
Old ford
Jul 31, 2015 06:50 AM
