Radio wiring help
Old Dec 27, 2008 | 06:25 PM
Nutroast's Avatar
Nutroast
Default Radio wiring help
Hoping someone can help me.
I've just got myself an Escort Ghia Estate 1992.
It doesn't have a radio fitted so i'm in the process of putting a CD player in, but cant work out the speaker cables...
There is a grey hank of cables with very thin wires inside. are these the speaker wires???
If so, can someone tell me whicjh is which as i'm getting power to the H/U but nothing out of the speakers.
Thanks in advance.
Old Dec 27, 2008 | 06:56 PM
burnzy's Avatar
burnzy
burnzy
hold on mate let me mooch through my haynes n i'll tell u wot's wot i had to do my 92 esco n have u swapped over the red n yellow wires cos othwise u'll be loosing your setting's everytime u turn the car off
Old Dec 27, 2008 | 07:05 PM
blueskies85's Avatar
blueskies85
yes deffo swap your wires over as burnzy sayd!
Old Dec 27, 2008 | 07:18 PM
burnzy's Avatar
burnzy
burnzy
ok unfortunatly ford decided that there sort of colour code is just not normal resulting in DIY testing
there is some sort of uniform though
3 of the speakers are
posotive wire to the speakers is yellow/black
negative wire to the speakers is white/black
with the white n yellow of the wires bein the main colour with a strip of black on them
then it say's right side rear speaker
posotive = yellow/red
negative = white/red
honestly don't ask lol but aslong as u keep the posotives n negatives the same n just find out by trial n error witch are the other three speakers by changing the balance n fader on your unit,
they do run in order on the original ford connector block if it's still there, that's the longish yellow one if i can remem, if u can read the numbers on the one side of the con block itself then the wires goin into the corresponding terminals are
front left speaker is #1/2
front right #5/6
back left #3/4
back right #7/8
i'm sure that's right but let us no if u have n e prob's
oh yea n if u can be arsed i would go to halfords n buy an iso block n connect that up instead u should have an iso connector with you stereo so if u ever want to chage unit again it's plug n play
Old Dec 27, 2008 | 09:14 PM
Nutroast's Avatar
Nutroast
front right #5/6
back left #3/4
back right #7/8
Thanks for that mate.
There are no blocks on the ends so im guessing im gonna have to try each 1
Old Dec 27, 2008 | 09:35 PM
burnzy's Avatar
burnzy
burnzy
Haha! sos that's ravin but yea just put your unit fader n balance so just a single speaker is working n work from there, n no prob's i no how much of a pain it can be
Old Dec 28, 2008 | 11:41 AM
Nutroast's Avatar
Nutroast
There are a total of 9 wires in the hank 4 pairs and a single wire?????
Old Dec 31, 2008 | 02:50 PM
Nutroast's Avatar
Nutroast
Angry
Managed to get it all wired up and was working fine, then the speakers stopped working.
I undid one of the connections and it started working again, but once again stopped.
All wires are bare and connected fine, can't figure out whats going on...
Any ideas????
Old Jan 1, 2009 | 12:40 PM
cabriolet's Avatar
cabriolet
speaker wire going to earth would do it fella had a kenwood do it to me
Old Jan 1, 2009 | 01:30 PM
burnzy's Avatar
burnzy
burnzy
sorry mate only just seen the thread n yea that sounds abit unusuall so try wot cabriolet say's have u a multi meter cos put it on ohm's n test the straight through the wire from end to end it should have a reading close to the same as when u touch both prong's together then from the sterio side to the bodywork this should have no reading at all, this way is easier but your best is to visually check it, n wot color is the extra wire n i'll look though the bible n let u no wot it must be cheer's
Old Jan 1, 2009 | 09:49 PM
Nutroast's Avatar
Nutroast
The extra cable is red, only get any speaker output by putting together with the white wire with red stripe. Rear Right
If this is not connected none of the speakers work.
Old Jan 3, 2009 | 01:31 AM
burnzy's Avatar
burnzy
burnzy
Hmm! right well that wire is your power wire n should be connected up to your yellow wire on the stereo n then the yellow wire from the dash should be connected to the red wire on your stereo, n also your black (negative) wire should be connected to the thick brown wire in the dash, n how do you mean there is no sound does the stereo light up but theres no sound or is there nothink at all, n have you made sure you'v gone through each speaker singley so you haven't crossed the speakers over i.e made sure that the positive n negative are both from the same speaker on each speaker.
if still no joy n you'v double checked your connection's as stated then the only thing left is to check the speakers themselves, if the unit has power then it should either be the speaker wires or speakers themselves presuming it's a brand new unit,
let me no how you get on
Old Jan 5, 2009 | 10:34 PM
Nutroast's Avatar
Nutroast
Unhappy
Right, as things stand from today.
Unit powers up fine.
All speakers are wired in properly, all speakers work.H/U is fine as i've tried it in my van.
The speaker cable loom in the car has 4 pairs of cables, 2 to each speaker, but within the loom there is a 9th cable. When i touch this on the rear right speaker connection it works.
Turn the H/U off and back on again i get nothing. Take the wire out and put it back in and on it goes.
Well stuck for ideas now......
Old Jan 6, 2009 | 10:13 AM
burnzy's Avatar
burnzy
burnzy
u dont have a ford amp on it do you id have a check cos it sounds like u might try putting that 9th wire on the blue wire of your H/U n see if that helps
Old Jan 6, 2009 | 11:53 AM
cos400's Avatar
cos400
have u sort this out yet
Old Jan 6, 2009 | 06:54 PM
Nutroast's Avatar
Nutroast
Thumbs down
No
I'm not far off from screaming into a pillow.
Old Jan 6, 2009 | 08:01 PM
burnzy's Avatar
burnzy
burnzy
how many cables have you all together mate is it 13
color H/U wire
brown = earth
brown/white = not used goes to car alarm
grey/yellow = radio illumination or dimmer wire
yellow = red wire head unit switched power
red = yellow wire head unit constant power
white/red = the rest are speaker wires
yellow/red =
white/brown =
yellow/brown =
2 X yellow/black=
2 X white/black =
the extra wire that is red should be a constant live to your head unit,
your head unit will still work with just the yellow wire connected but not properly
you could also have a short somewhere on a speaker wire knocking out the in built amp inside the H/U, but tbh you shouldn't have the red wire connected up to the speaker something sounds desperatly wrong, check your power cables first if they are all correct then i think your last option is to put your own speaker cables in
Old Jan 6, 2009 | 08:04 PM
cabriolet's Avatar
cabriolet
i know jts obvious have u got a toggle switch by the steering column ford bastardised the speeker connections if so re wire the speakers its easier fella unplug the front speakers under the kick panel covers and connect up new run new wires to the back speakers job done
Old Jan 8, 2009 | 04:57 PM
dylansdaddy's Avatar
dylansdaddy
Sierra Sadcase
Hi thee sounds to me like you have got the ford setup with an amp and the wires you can see are data wires feeding a sperate amp. Only way to sort it is get a new lead and standard ford stereo or trace the grey flat cable back to the standard amp and the speaker outputs are plugged into the amp usually with white and trace colors. You can extend the wires or try to make it reach the new head set. hope this helps
Old Jan 8, 2009 | 09:29 PM
Nutroast's Avatar
Nutroast
All been sorted now.
Reason??? See above, bloody built in amp.......
Thanks peeps for all ya help
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
