Zetec crank swap
Old Dec 26, 2008 | 01:10 PM
cabbykarl's Avatar
cabbykarl
Question Zetec crank swap
Hi all and merry Christmas....
ok, bottom end knocking off load above about 2000rpm, oil pressure light coming on...sounds like big ends to me so...
If I get another zetec block (1.8) can I take it's crank out and get new standard size shells if it seems unworn and put it into my block?
Only reason I wouldn't just swap for another is that my block's been converted for ZVH use ie pistons skimmed, breather blocked and relocated, oil return put in and head oil returns blanked off.
Or are cranks not too interchangeable as in blocks line bored to 'grades' so different sizes?
Any help's gratefully taken....
Karl.
Old Dec 26, 2008 | 01:13 PM
jacko's Avatar
jacko
all silver top cranks are the same 1.6 to 2l
Old Dec 26, 2008 | 01:27 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
i think he means are they interchangeable from one block to another
eg the main caps are not really interchangeable
Old Dec 26, 2008 | 05:39 PM
cabbykarl's Avatar
cabbykarl
ok, thanks for the replies. I'm off to the garage tomorrow so i'll drop the sump and assess the damage before any drastic transplant operations!
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
grishenko45
Sep 9, 2015 12:58 PM
