oil seal
Old Nov 20, 2004 | 07:22 PM
THE RADMAN's Avatar
THE RADMAN
Default oil seal
any advice on renewing front crank oil seal on esc cos? i was looking at microcat and it looks like there are 2 seals,one inside the front cover plate[which has been renewed twice before], and another behind the cover, is this right ? as im fed up of mine pissing oil out ,i thought if i do it myself ill renew the lot to make sure,any ideas?
Old Nov 21, 2004 | 02:09 PM
THE RADMAN's Avatar
THE RADMAN
BTTT
Old Nov 21, 2004 | 10:08 PM
velocity's Avatar
velocity
there is only one seal for the crank at the front which is pressed into the front cover.there is a sump seal also on the cover and a gasket which also takes in the aux shaft cover.
what you need to do is remove the front crank pully and pry out the old seal which is tricky enough, taking care not to damage the aluminium cover.and then tap in a new seal,taking care no to damage the inner knife edge of the seal when pushing it up on to the crank journal,
Old Nov 22, 2004 | 06:30 AM
THE RADMAN's Avatar
THE RADMAN
cheers,is it easier to remove the cover at the same time or does that involve more probs? just thought it would be easier to get the seal out then
Old Nov 22, 2004 | 10:43 AM
velocity's Avatar
velocity
it would be easier to remove the seal if the cover was off but it may cause a few problems when trying to make sure it seals up properly when reinstalling,as you also have to remove some fwd sump bolts aswell,
the only difficulty is removing to old seal.and once its out its very easy to install the new one,and with less work involved than putting on the front cover.
i would try this way first and if all else fails you can always go the other way
Old Nov 22, 2004 | 09:22 PM
THE RADMAN's Avatar
THE RADMAN
cheers velocity
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fudgey
21
Sep 30, 2015 06:19 PM
