Rev Counter fitting
Old Dec 24, 2008 | 04:53 PM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Default Rev Counter fitting
Hi all, I have a small problem, in that i have a 1.3 cross flow engine and 4 speed gear box from a escort mk 1-2, but sadly there is no rev counter fitted. can someone tell me how i can fit a rev counter to this engine.
Old Dec 24, 2008 | 04:56 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
if you buy a rev counter it will tell you to conect one of the wires to the coil
Old Dec 25, 2008 | 01:52 AM
As above but make sure that your rev counter will work with your ignition type(especially if changing/defo recommended), or at best it will be innacurate, at worst just not work.
They are all fed from the negative(switched) side of the coil, on fords escort mk2's etc from a extra green wire on the coil itself, that goes all the way back to the rev counter.
What make rev counter are you using ?
Dahl88
Aug 22, 2015 08:16 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
