Saph idling problem help please before i go nuts
Old Dec 22, 2008 | 08:41 PM
carlo's Avatar
carlo
Default Saph idling problem help please before i go nuts
My car idles abot 1000 rpm when you come to a sudden stop after loading it up or going hard it just cuts out.When you slow down nice & easy it idles fine.
I have cleaned the iscv soaked it in oil all night never made any difference.
What else can cause this as its going to end up foooking my turbo as its cutting out when piping hot.2wd saph cossie forgot to add
Old Dec 23, 2008 | 01:15 AM
Checked your CO yet ?, a weak mix will do this no problem.
Old Dec 23, 2008 | 03:01 AM
Fezza's Avatar
Fezza
H71 CNX
Check your vacum pipes too.
Old Dec 23, 2008 | 07:22 AM
carlo's Avatar
carlo
afr is 11.2 on idle & there is no air leaks
Old Dec 23, 2008 | 09:42 AM
carlo's Avatar
carlo
Surley someone has had this prob before?
Old Dec 23, 2008 | 10:31 AM
stevenebm's Avatar
stevenebm
post whore
hate wee problems like that mate.hope you get it sorted
Old Dec 23, 2008 | 10:41 AM
carlo's Avatar
carlo
So do i mate im getting through them slowly always the same when you build a car out about 5 other cars
Old Dec 23, 2008 | 06:09 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
does your iscv actually work?
Old Dec 23, 2008 | 06:15 PM
pee vee's Avatar
pee vee
11.2 at idle!? thats a bit rich aint it (for idle )
Old Dec 23, 2008 | 06:27 PM
11.2 at idle, I would sort that first.
Old Dec 23, 2008 | 07:58 PM
carlo's Avatar
carlo
What do you want it at idle? the iscv works when cold dont notice any difference when warm
Old Dec 23, 2008 | 08:00 PM
JTECH James
Passion for Fords!
14-15 at idle when hot
Old Dec 23, 2008 | 08:03 PM
carlo's Avatar
carlo
Cool maybe that will be why its idling like fook all then
Old Dec 23, 2008 | 08:06 PM
JTECH James
Passion for Fords!
yours is running cold start rich all the time by the look of it lol
Old Dec 23, 2008 | 09:58 PM
carlo's Avatar
carlo
do i just adjust that with the co screw on ecu?
Old Dec 24, 2008 | 07:56 AM
If you know exactly what chip etc is in it, I would take it along to a rolling road, just for a check up at same time, should only be a hours labour, but peace of mind.
Old Dec 24, 2008 | 08:19 AM
carlo's Avatar
carlo
Its been on the rollers & is fuelling ok just a bit rich on idle.Is it just the screw on the ecu that i can bring it back a bit to make it a bit leaner
Old Dec 24, 2008 | 12:28 PM
JTECH James
Passion for Fords!
in theory it will bring the idle co down by adjusting the global mod( ecu screw) but the problem is this screw will trim the whole fuel table as a percentage, so it will also weaken it off at the top....
make sure you havent got a faulty map sensor, ect,act sensor, as these can cause this sort of rich running faults...
Old Dec 24, 2008 | 12:56 PM
carlo's Avatar
carlo
Every engine sensor is new but i know there could still be a faulty one.I will check it out & try get it a bit leaner on idle im sure flat out the car was running a tad rich anyway so got a bit adjustment to go.I said above the fuelling was ok on rolling road what i meant is that it wasnt lean
Old Dec 25, 2008 | 11:30 AM
pee vee's Avatar
pee vee
well i'd just replace the ECU water temp sensor (blue 2 pin plug one)
as that (if any) will be the one making the ecu think it should be on cold start all the time
i'd do this before messing with the CO screw. as your settings will all be out if you play with that!?
Old Dec 25, 2008 | 11:45 AM
BigErn's Avatar
BigErn
agree with pee vee on this one.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
RSmark84
Sep 13, 2015 01:29 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
