Few zetec Q's
Old Dec 19, 2008 | 02:49 PM
*Bri.4.b.Cos*'s Avatar
*Bri.4.b.Cos*
Default Few zetec Q's
I will be putting in a 2L silver top zetec on a IB5 gearbox with rear mounted starter into my fiesta RS1800 over the winter.
Will be keeping the 130 spec management that originally came with the car, have fitted a 4-2-1 manifold and decat, ported throttle body and port matched manifolds
1st Question is will the 2L be OK running on the original 130 spec management with the 2L injectors instead of the 1800 one's ?
2nd Question is head porting for n/a should the inlet and exhaust be done or just the one ?
3rd Question is i have some verniers, is there any thing else to be had out of the STD 2L cams or the 1.8 130 spec ones ?? and which ones to use with the 2L
4th Question raising the compression ratio slightly good or bad ?, i would personally deck the block slightly but could skimming the head do the same ?
Thanks in advance for any help / ideas
Bri.
Old Dec 19, 2008 | 03:33 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
1. No.
2. You don't want to do any porting if using the standard intake.
3. Standard zetec pulleys are fully adjustable already.
4. Increasing the CR will give you more power.
Old Dec 19, 2008 | 04:26 PM
*Bri.4.b.Cos*
Originally Posted by pa_sjo
1. No.
First off thanks for the reply
1. so use the 1800 ones then????
2. could you explainy why
3. which cams would be best and can there be any gains from altering the cam timing on std cams
4. can a head skim raise the comp the same way decking the block will and is which would be best
cheeRS
Bri
Old Dec 19, 2008 | 04:40 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
1. You should use the ECU, injectors and MAF from the engine you intend to run. Using anything else will give less-than-perfect results.
2. Increasing port size without removing the restrictive component (eg the inlet manifold etc) will do nothing but make the engine 'soggy' and give you no more power.
3. Standard cams are best for a standard engine. Ford did a pretty good job at timing them in from the factory.
4. Machining the head is preferable. You should be able to get away with 1.5mm (on a fresh head) without piston-to-valve contact. You should measure what clearance you do have before making changes.
Old Dec 21, 2008 | 05:56 PM
richard_syko's Avatar
richard_syko
Focus RS (maybe same for all duratecs) have steel head gasket has been fine on my engine for a quick fix of upping the CR.
about 35 quid from Ford.
Old Dec 21, 2008 | 06:07 PM
rst in breaking's Avatar
rst in breaking
would the simple option not be to get the proper ecu for the £10 or whatever it costs so it fuels correctly?
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
