Mondeo suspensoin knock ??
Old Dec 17, 2008 | 06:20 PM
V6 Ste's Avatar
V6 Ste
Default Mondeo suspensoin knock ??
My mondeo 2 litre Si (1998) has developed a knock on the rear suspension . It sounds like the drivers side and is when i corner or go over a bump. Had the wheel off and had a look, all bushes look like new or sound condition. Any suggestion ta .
Old Dec 17, 2008 | 06:25 PM
Im sure the mondeos have anti roll bar link rods on.If they do get under the car and give them a wiggle.You should be able to feel if there is any play in them.
Old Dec 19, 2008 | 08:39 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
I'm pretty certain it will be the rear anti roll bar drop links, anti rollbar buhes or even both.
Used to change loads when I worked at fords.
Old Dec 19, 2008 | 09:54 PM
Marshin's Avatar
Marshin
defo sounds like a drop link mate, had the same problem on my st200!
Old Dec 20, 2008 | 01:55 AM
As above as a first check, then the shock itself after that.
Had a knocking last year on my dads mondy(2L ghia) was down to rear shocks, changed them and my god what a better ride for it, used pattern ones but really good and cheap too.
Old Dec 20, 2008 | 06:27 PM
V6 Ste's Avatar
V6 Ste
Thanks very much, you were all right and I've sorted it now. Drives a lot better and got rid of the knocking.
Old Dec 20, 2008 | 06:28 PM
Sweet glad you got ot sorted.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
