C20LET pistons....
Old Dec 16, 2008 | 09:27 PM
OwenS's Avatar
OwenS
Default C20LET pistons....
I'm new and have tried using the search facility.
I'm beginning to build a 2.0 Zetec Turbo...i plan to use the LET pistons (2nd hand) Is it ok just to use these. They're out of a low mileage engine...If so, do i just replace the rings?
Thanks.
Old Dec 16, 2008 | 09:42 PM
coswurv's Avatar
coswurv
Thanks.
If you use the standard zetec rods you will have to have the little end honed out slightly to take the gudgeon pin, plus the cylinders rebored.
Old Dec 16, 2008 | 09:46 PM
OwenS's Avatar
OwenS
Yeh read about that....was going to be using the LET rods also. Is that a better option...would imagine the big end would need bored out? I just need to know if 2nd hand pistons and rods will be up to the job?
Thanks
Old Dec 16, 2008 | 09:58 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You won't be using the GM rods........
Old Dec 16, 2008 | 10:01 PM
OwenS's Avatar
OwenS
Oh ok....are the Zetec ones good enough?
Old Dec 16, 2008 | 10:20 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Good enough for what?
Old Dec 16, 2008 | 10:21 PM
OwenS's Avatar
OwenS
Good enough for a Zetec Turbo conversion.
Old Dec 16, 2008 | 10:25 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
That'd depends on several factors: 1) What power? 2) What torque 3) Quality of build 4) Quality of mapping.
Old Dec 16, 2008 | 10:32 PM
OwenS's Avatar
OwenS
Fair point...unsure about the answers to all of those questions because the engine hasn't been built. Looking for around 270BHP..would the 2nd hand LET piston and the Zetec rods cope with this estimated power?
Old Dec 16, 2008 | 10:34 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yep, if done properly.
Old Dec 16, 2008 | 10:37 PM
OwenS's Avatar
OwenS
Thanks....
Properly? Anything advice/tips? I'm sure you've repeatedly been asked these questions, however i've tried to do as much research as i can.
Old Dec 17, 2008 | 10:08 AM
JamesR1's Avatar
JamesR1
Anybody for a brew?
If you use zetec rods, you also need a oil feed hole putting in the little end. As the zetec as standard arn't floating but the LET is. 270BHP is considered about the upper limits of STD zetec rods.
Shame as i'v just sold a set of Modded zetec rods and decent LET pistons.
Old Dec 17, 2008 | 10:31 AM
RS 5tu's Avatar
RS 5tu
How much did you sell them for?
Old Dec 17, 2008 | 10:32 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Why would you do that, as most people run this pacakge semi-floating?
Old Dec 17, 2008 | 12:28 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
i think this is done to aid lubrication as the oil spray bars dont function properly with those pistons, www.powerconversions.co.uk are the people to speak to on this, gave me loads of advice on this and they can carry the neccessary work out for you.
Hope this helps
Old Dec 17, 2008 | 12:38 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Raj_FRST- huh? That doesn't make sense. The piston cooling jets work just fine with those pistons? I'm still confused as to why someone/you thinks drilling a hole in the top of a rod in a semi-floating application is going to make the slightest bit of difference to anything (other than technically making the rod weaker).
Old Dec 17, 2008 | 01:25 PM
Raj_FRST's Avatar
Raj_FRST
well it is above my head, I remember the bloke explaining how when the let pistons are used they need to be bronzed bushed or something similar as the standard spray bars are obstructed, i cannot personal vouch for this info as I have never done this sort of conversion, just trying to throw a bit of info in
Old Dec 17, 2008 | 02:17 PM
JamesR1's Avatar
JamesR1
Anybody for a brew?
i sold them for Ł350 to some lad who was overly desperate. without rings.
It was ian howell who said the oil feed hole was needed. The let Piston and Zetec rod set up is floating.
The underpiston jets work fine when using let pistons.
Old Dec 17, 2008 | 05:36 PM
jammy86's Avatar
jammy86
how much is a set of LET pistons?
JAmes.
Old Dec 17, 2008 | 06:01 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
i have got some for sale only done 5k
pm for price if anyones interested
rsguy
28
Jun 13, 2007 12:45 PM
jason len
May 10, 2006 10:35 PM
jason len
May 10, 2006 10:51 AM
