cosworth saphirre 2wd for 450bhp?
he
he
what the engine configue for 450bhp?
i'm
-turbo T04B 70mm and trim 54, turbine 0.63 escort cosworth
-intercooler RS500 radtec 60mm
-exausht mangoose 76mm
-injectors 403
-map 3 bar
-ful pomp 044
-swedish plenum
-throttle body std
-cams std
-gasket cometic
-stuk arp head
-ratio comp 8:1
Thank's you for you reponce
he
i'm
-injectors 403
-map 3 bar
-ful pomp 044
-swedish plenum
-throttle body std
-cams std
-gasket cometic
-stuk arp head
-ratio comp 8:1
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
