s2 turbo unit seized??help
Old Dec 13, 2008 | 11:28 AM
RScrew69's Avatar
RScrew69
Default s2 turbo unit seized??help
Hi folks,
I have a stage 2 hybrid turbo thats been rebuilt for one of my rs turbo's. Its been sitting in my car and has been used done about 8000 miles.
I went to the car to do some work today and the turbo is seized, well the spindle shaft is just stuck.
Now whats the best way to free it up?
I was considering filling it with oil or does it need oil pressure vis oil pump and engine running?
any help appreciated
cheeRS
Old Dec 29, 2008 | 10:40 PM
RScrew69's Avatar
RScrew69
anyone?
Old Dec 29, 2008 | 10:43 PM
mk2rstaff's Avatar
mk2rstaff
would whack some wd40 in there mate let it settle for a bit, but to me that kind of says it fooked mate, any idea if anything has spilt on it like water or something while its been sat, cos if the shaft is rusted it will deteriorate mega quick if it goes back on the car???????
Old Dec 30, 2008 | 10:37 AM
RScrew69's Avatar
RScrew69
is that in from where the oil feed is bolted on? or where u can touch the blades from with the wd40.
cheers mate
Old Dec 30, 2008 | 10:45 AM
andyuk's Avatar
andyuk
Default turbo
cheers mate
hi mate i would just fill with oil from were the turbo oil feed bolts on as when turbos are new they say to do this to prime it, and check that it comes out the other side on return, leave for a few hours and then try,
Old Dec 30, 2008 | 11:03 AM
RScrew69's Avatar
RScrew69
ok thankyou, i'll give that a go and see how it responds
Old Dec 30, 2008 | 11:52 AM
mk2rstaff's Avatar
mk2rstaff
also when you start the engine when its on take the coil lead off and just turn the engine over to pump oil through the system before you fire it up
Old Dec 30, 2008 | 01:02 PM
RScrew69's Avatar
RScrew69
ok so prime the engine basiclly with turning it over and having coil lead disconnected will get oil into turbo etc. save damging it i guess with oil starvation
Old Dec 30, 2008 | 01:07 PM
mk2rstaff's Avatar
mk2rstaff
that is correct mate, i do it to my cars when they have not been driven for a few weeks or so, just to be on the safe side
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
marky_g
Aug 19, 2015 11:46 AM
