89 reg mfi xr3i stalling
Old Dec 10, 2008 | 06:52 PM
steveo69's Avatar
steveo69
Default 89 reg mfi xr3i stalling
Ok,have had new cam and tappets put in today and also had thermostat housing off and cleaned and a new thermostat put it,as well as fresh water/anti freeze.
Went to start it and it ran fine for about 5 minutes then cut out.
As needle is crap didn't think it was out of fuel but put a can in and has been stalling every time I slow down,and sometimes starting then cutting out straight away.
Another thing is,when it has been idling ok,by way of the idle screw,I put lights on and it cuts out again.
Any ideas?
Please help lol!!!!!!!!!!!!!!!!!
Old Dec 10, 2008 | 11:01 PM
Smartdj.'s Avatar
Smartdj.
sell it asap is my idea............how did u run the cam in and how long????
Old Dec 11, 2008 | 12:40 AM
steveo69's Avatar
steveo69
Well apart from letting it idle until it first stopped we have kept at it and finally got it running so have taken it for slow drive round for 20 mins then let it idle and seems loads better.
As the car was over cooling before,could it be an issue with it reaching proper working temp now?
Gonna see how it goes and what happens now,will post any changes.
Old Dec 11, 2008 | 07:21 PM
steveo69's Avatar
steveo69
Well have narrowed it down to a fan heater fuse that had blown,and a headlight reley playing up so stuck new ones in and all is ok now.
Old Dec 11, 2008 | 07:53 PM
haz87's Avatar
haz87
Those fuse's wouldn't effect idle.. are you sure you set the ignition timing back properly? And did you disturb any vacuum hoses as its easily done on the mfi
Old Dec 11, 2008 | 08:01 PM
steveo69's Avatar
steveo69
Well we checked all over pipes and stuff,but as it was stalling if we put lights and heaters and stuff on as well we checked those.
Have also tinkered with the timing too and has made a difference.
Old Dec 11, 2008 | 08:35 PM
Smartdj.'s Avatar
Smartdj.
correct me if im wrong but to run in a cvh cam in dont u let it run at 3k or above for 20 mins atleast???
Old Dec 13, 2008 | 12:53 AM
steveo69's Avatar
steveo69
Nice one mate I didn't know that,cheers
Running nice now.
Old Dec 13, 2008 | 03:09 AM
Smartdj.'s Avatar
Smartdj.
oooh god you will be so lucky if it hasnt damaged the lobes
bobsworth
77
Mar 24, 2016 09:30 PM
gcfcos
59
Oct 6, 2015 05:04 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
gingeRS
17
Oct 2, 2015 09:42 AM
