t34 turbo advice
Old Nov 29, 2008 | 05:10 PM
proboscus's Avatar
proboscus
Default t34 turbo advice
im thinking of buying a t34 turbo it is fitted with a restrictor on the air inlet housing.obviously i would be wanting to remove it.if it was removed could i just put the intake hose directly onto the housing or are any other mods required?
Old Nov 29, 2008 | 08:26 PM
So long as it's the std .60 AR compressor housing as used on the cossies yes, the restrictor (34mm) is a tube like device that goes inside the main inlet, and is held by bolts going through the flange that secures the normal pipe, this then extends out about 2 1/2" and the pipe then goes on this bit, but yes restrictors are removable just a few bolts, normally three.
The 34mm restrictors are used in certain racing classes but are certainly not a limit till well over 300bhp anyway.
big_Rad
Sep 15, 2017 09:36 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Danielbetty
Aug 23, 2015 12:52 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
