mk1 mondeo rear disc conversion
Old Nov 29, 2008 | 03:47 PM
skrats's Avatar
skrats
Default mk1 mondeo rear disc conversion
as above ,
My car has drums at the moment so i want to disc it up on the back ,, will my discs front and rear fit of my saph or will it be easier to do it with st24 set up ??
Old Nov 29, 2008 | 04:09 PM
studabear's Avatar
studabear
sure mk2 mondeo bits should go on very easily, if not straight on
Old Nov 29, 2008 | 08:27 PM
Sierra stuff doesn't fit, mk2 mondy does though.
Old Dec 1, 2008 | 06:47 PM
tarmac terriost's Avatar
tarmac terriost
v6 stuff fits a treat just swop the rear hubs and cables off a v6,also can reconmend mrk3 mondy calipers with st170 focus disc and mrk3 mondy pads also will need spacer to fit the calipers makes a huge difference also fit the goodridge braid hoses front and back
when doing the conversion recomend you change the handbrake lever as the self adjusting ratch packs up if you want a how to on both set ups
check out www.fordmondeo.org
YODI
Aug 30, 2015 01:12 PM
james kiely
Aug 28, 2015 08:58 PM
RsS2daz
Aug 14, 2015 05:26 AM
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
