Roll cage spec's
Old Nov 26, 2008 | 04:32 PM
G Beale's Avatar
G Beale
Question Roll cage spec's
Hello everyone, I think this is my 1st post on here although I registered ages ago to look at some pic's of a girls norks as I recall ! lol
Right so now you all know I'm a perv' I would like to know what diameter & wall thickness steel tubes I should use for a roll cage in my next project mk3 Escort thingy. I have access to as much steel as I like so no prob's there but as this is going to be the only welding I do to the shell (hopefully) then I want to get it right 1st time.
Would I be right in thinking that the main "hoop" & maybe a couple of braces for it should be the sturdy items and then the rest can be a bit thinner ?
I will be designing & bending it myself so it's never going to be perfect but should give anyone who sees it a good laugh !
Old Nov 26, 2008 | 08:19 PM
LHD220Turbo's Avatar
LHD220Turbo
not many people look in this room; maybe better to post in general discussion bud
incidentally i dont know; maybe google roll cages and see the tech spec of what people are using
Old Nov 26, 2008 | 08:44 PM
G Beale's Avatar
G Beale
Cheers mate, no worries I'll probably just end up using what ever bends the neatest.
Old Nov 26, 2008 | 09:11 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Cold Drawn Seamless Tube is what you need
Wall thickness and tube diameter are personal choice tbh and what you want from the cage (structural? just protection?). I have a main hoop piece in the garage I might be able to measure up soon if your really stuck.
Failing that ring up a custom cage builder, tell them your requirements and ask them what they recommend for your needs, sneak in the question about diamers and wall thicknesses.
Dan
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
SMILER258
Sep 28, 2015 09:04 AM
Mikersturbo
Sep 27, 2015 07:43 PM
