3dr Cooling fans fuse melted ?????
my 3dr cooling fans fuse has melted , and i mean proper melted - right on to the acutally base of the box and destroyed the terminals - any ideas or has this happened in any of your 3drs or saphs - WAS a 30 AMP fuse
I wouldn't put any lower power/speed/airflow fans on as the cossie cooling system is marginal at best.
A newer design like curved blade may be a lot more effecient and cut down on current, but a lot of money when a rewire sorts it.
