efi vs mfi
Old Nov 22, 2008 | 08:03 AM
BIG_AL_R's Avatar
BIG_AL_R
Default efi vs mfi
hi i was wondering,
i currently have a efi fiesta engine, whats the differance between this and an mfi 1????
i need a new bottom end what i need to know is can i use an escort turbo bottom end or is it different???
i know the s1 need the cps modifyed but im pritty sure its just a case of connecting a s2 bottom end up???? is his the case?
on a further note if i can get a whole engine will what differances do the heads have?
will a mfi head be able to bolt up to a efi unit?????
HELP
Old Nov 24, 2008 | 04:01 PM
Jonnie_d's Avatar
Jonnie_d
I have undertaken this conversion and there are no differences from my knowledge to the bottom end other than the cps hole.
The cylinder heads are different tho as the efi inlet has different mounting studs to the mfi.
I went from an MFi engine to efi and changed the cylinder head and inlet etc. The escort (T3) exhaust manifold bolts straight on tho.
Hope this helps
steve.rst
Mar 15, 2016 08:01 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
stevierob
Sep 7, 2015 07:09 PM
