oil light flickering?
Old Nov 21, 2008 | 03:16 PM
luke_rsfesta's Avatar
luke_rsfesta
it always needs something
Default oil light flickering?
i have a fiesta rs turbo and the oil light keeps flickering,only when its get up to temperature and only in low idle where it stays solid until i press the accelerator.ive just had a new t3 turbo fitted,the oil level is a little bit high but not loads id say 2mm over the max line,it just puzzles me can any1 help thnx
Old Nov 21, 2008 | 03:21 PM
andyuk's Avatar
andyuk
Default oil
hi mate this was my mates old car andys i have worked on this a few times, you might have a faulty oil pressure swicth, check it
Old Nov 21, 2008 | 03:23 PM
t31ryt's Avatar
t31ryt
I have the same issue and been told the above or wrong oil
Old Nov 21, 2008 | 03:26 PM
luke_rsfesta
ok nice one,also it dont like sitting in traffic gets hot quite quick and overheats,any ideas on that?
Old Nov 21, 2008 | 03:51 PM
t31ryt's Avatar
t31ryt
get a new fan switch and thermostat....also consider a second fan switch
Old Nov 21, 2008 | 04:19 PM
B16CVH's Avatar
B16CVH
Check in this order
1) Correct Oil then,
2) Change Oil Presure Switch, if still no good,
3) Check oil pump pressure, if still no joy, then the engine is more than likely fubared!
Old Nov 22, 2008 | 10:54 AM
If it isn't the switch, or the wrong/old oil then personally if it is running ok and only doing this at idle when hot I would just keep using it, otherwise it's a engine strip needed.
What is the idle speed, as if too low this will aggravate the light.
Old Nov 22, 2008 | 04:48 PM
t31ryt's Avatar
t31ryt
mines abt 9
Old Nov 22, 2008 | 04:57 PM
LHD220Turbo's Avatar
LHD220Turbo
what oil are you using?
could be a number of things
when its at idle; is the engine noisy? does it sound healthy?
check what everyone else has mentioned, plus check the oil pick up pipe; i've seen these get blocked before and cause oil pressure problems
Old Nov 22, 2008 | 09:27 PM
luke_rsfesta
engine sounds very healthy and doesnt idle too low,gona do an oil change tomorrow cus i think thats the quickest and easiest 1st
Old Nov 22, 2008 | 09:28 PM
luke_rsfesta
noticed tody that its not boosting past 5psi,and is capable of up to 20,not sure how to adjust it??
Old Nov 22, 2008 | 09:30 PM
luke_rsfesta
its 10w 40 oil at the mo by the way
Old Nov 29, 2008 | 06:43 PM
luke_rsfesta
its sorted changed the oil for 10w 50 and put new oil pressure switch on and its all good now thnx guys
Old Nov 30, 2008 | 01:28 PM
B16CVH's Avatar
B16CVH
I will say, too late now tho, use the cossie switch as it will come on at a higher pressure meaning you will be less likley to cause damage to the engine if something were to happen!
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
