FRST fuel pump question.
Old Nov 16, 2008 | 08:56 PM
Garry J's Avatar
Garry J
Default FRST fuel pump question.
Hiya All,
Question about the fuel pump, when the ignition is switched on does the fuel pump prime until it reaches a certain pressure then switch off or does it continually pump ?
If it pumps until it reaches a certain pressure what controls this, is it ECU controlled, fuel pressure regulator controlled??
Basically, for the first time since getting this FRST as a rebuild project, i got a battery on it today to sort out an alarm issue, when i switched the ignition on i got NO dash lights, the car wouldn't crack over and the fuel pump was constantly priming without shutting itself off and after 5-6 seconds the pump began to labour under pressure but continued to pump, just not sure if its meant to shut down when pressure achieved.
Ignore the fact there is no ignition lights, think that is alarm / immobiliser related so will look further in to that another time unless someone can confirm there directly related in some way.
Thanks
Garry
Old Nov 16, 2008 | 09:39 PM
nobbie_b's Avatar
nobbie_b
hi mate i have been having problems with my cossie not starting and i have been told the fuel pump come on to prime its self for about 3-4 seconds then shuts off then will pump when needed after the car has started. my car does this but dont start ha ha b
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 27, 2015 04:55 AM
15
Oct 7, 2015 03:43 PM
Marino
Sep 12, 2015 11:10 AM
Bransby
Sep 11, 2015 01:09 AM
