Escort alloys on Escort Van?
Hiya
I bought these escort alloys (at least the bloke i bought them off said they were, i have seen fiestas with similar wheels) thinking they'd bolt right on to my van.
However, when i tried to attach the wheels, the tool i have for removing wheel nuts wouldn't fit into the recess, meaning i couldn't tighten the nut enough (3 or 4 mm of play)
My van has the stud + nut type fixings for the wheels (is that the right terminology?), i was wondering if it needed to be the other type (whatever thats called).
Any help greatly appreciated
Also, i had tried to put some photo's in there for you to see but they don't seem to work... code looks ok but im no expert...
here are the links,
first paragraph-
http://img293.imageshack.us/my.php?i...c006512nk3.jpg
second paragraph-
http://img184.imageshack.us/my.php?i...c006532wd5.jpg
third paragraph-
http://img184.imageshack.us/my.php?i...c006542rm8.jpg
sorry about that, any help on how to get images into posts would also be appreciated
here are the links,
first paragraph-
second paragraph-
third paragraph-
the wheels you have are escort cosworth lookalikes and are either mondeo zetec s wheels (16") or escort GTI wheels (15") , they were also available in 14" as an accessory
they will be a direct fit for your van as all 4 stud fords have the same bolt pattern
by the sounds of it you are trying to use wheels nuts designed for steel wheels , if this is the case you need to get hold of some alloy nuts as using steel nuts with alloys is very dangerous !
I have got the same wheels on my mk 6 van, if they are the 16" mondeo wheels.
i had to put longer wheel studs in the hub first, and use alloy wheel nuts.
if you have 205 tyres you will also need a 10mm spacer on the back.
hope that helps
hope that helps
Got them on now
Not sure how long theyre gonna stay there though, theyre only the 14's so they look a bit silly on the back now
I'll keep an eye out for a set of the mondeo ones, you got a picture of yours Dean?
How do you put longer studs in and where can i get 2 spacers from?
Alloy wheels and ICE for sale
14
26-09-2015 05:40 AM
