Heater Blower , Blown Fuse
Old Nov 8, 2008 | 05:19 PM
David Boylan's Avatar
David Boylan
Default Heater Blower , Blown Fuse
New to forum. I know this topic has been covered but i need some advice, I have had the problem of rain water getting in through the pollen filter and filling the passenger well , and i think that it has possibly caused a shorting out of some component as i can't get my blower to work i found the fuse for it in the engine compartment but when i change it , it blows straight away.
1. Could the problem be the Thermal Resistor
2. Could i disconnect it then put a new fuse in to see if it blows the fuse
Regards Dave
Old Nov 8, 2008 | 08:02 PM
I can only guess at what car you are talking about ?, but on some the motor is directly below the pollen filter/air intake, and water can drip down and short the motor, usually ok if motor taken off and dried out though.
It is normally I have found the base of the pollen filter assembly that leaks, I take these off and seal with loctite 5900 or 5910, then screw back down end of leaks, on others I beleive there is a bit of the upper part that secured to the firewall/bulkhead that breaks leaks.
Old Nov 9, 2008 | 09:18 AM
David Boylan
Hi posted the same question on another Ford forum and it is looking like water may have got on to the blower motor and damaged it , your right about the water , where the windscreen meets the plastic gutter the seal has gone i think it's a job for silacone
Old Nov 9, 2008 | 03:02 PM
To be honest silicone is crap, I use LOCTITE 5900 or 5910, a bit pricey but only needs doing once with this stuff, failing that use either a flange sealant or gutter seal.
IainRS1700T
Sep 25, 2015 06:44 AM
Flatlinedan
Sep 18, 2015 12:41 PM
