Handbrake Problems
Old Oct 29, 2008 | 10:35 PM
damo86's Avatar
damo86
Default Handbrake Problems
I am having trouble with the handbrake on my saph. Basically the handbrake does not work. At first i put this down to the cable being faulty so i replaced the cable with a brand new one. This still didn't fix the problem. i am now suspecting that it is the calipers that are the problem. my question is how difficult would it be for me to take the caliper apart and clean it up. Or would it be easier to just source 2 new rear calipers.
Damian
Old Oct 29, 2008 | 10:45 PM
westus1's Avatar
westus1
famous problem mate, the handbrake fulcrum siezes inside the caliper,
best bet is just to find 2 new 1's mate
Old Oct 29, 2008 | 11:09 PM
damo86's Avatar
damo86
thought as much. Cheers Mate. In the mean time is there a solution that would make it slightly better?
Old Oct 30, 2008 | 08:51 AM
You could try knocking the mechanisim back and forth, but it may stick on then ?
BIGGRED.CO.UK are ace for brake stuff.
Old Oct 31, 2008 | 01:11 AM
mk2rstaff's Avatar
mk2rstaff
as tabethat says, on top of the caliper there is the bit your cable attaches too, get a hammer and somee wd40 spray loads on the gently and manly work it back and fore, not a long term thing but will stop it binding if they are stuck on, or just operate if they are off
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
