Losing spark when warm 3dr level6 ecu
Old Oct 28, 2008 | 12:01 AM
1993cc's Avatar
1993cc
Question Losing spark when warm 3dr level6 ecu
Problem kicked off 2weeks ago,filled up,and drove off,car jolted as if electrics switched off,engine ecu warning light came on,but car still ran,drove into town car park and as engine revs dropped she died on me,took out plugs no spark,towed home,replaced ecu and coil started no probs,then week later started on the button,drove 3 miles and ecu light on again,just got home,then dead again,when shes cold runs no problem,getting fuel pump buzz as usual,done auto data ignition checks,with ign on and a volt meter across the ignition amplifier plug terminals 15 and 1 i cant get a circuit unless its pluged into the amplifier,any ideas gratefully received
Old Oct 28, 2008 | 12:09 AM
BigErn's Avatar
BigErn
Crank sensor maybe? They tend to act up when they get warm if they are breaking down.
Old Oct 28, 2008 | 07:55 AM
Cps would be my first thing to look at too, when it is running do the wiggle test on all the connectors.
New connectors are only around £3 or so, usually the female side that plays up, but that's about right!!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
griffo69
Oct 4, 2015 11:58 AM
martynhomer01
Oct 1, 2015 12:05 AM
deathrider666
Sep 28, 2015 06:12 PM
