Problems with heater, Ford Fiesta 2002 1.3 Finesse
Hi
I'm new to the forum.
Just looking for some advice.
The blower/fan for the hot/cold air has stopped working in my Fiesta, actuall so has the cigarette lighter. It's a 2002, 1.3 Finesse.
I've checked the fuses and they seem to be fine
Any ideas???
Thanks
Any ideas???
Thanks
Focus St mk2 310 bhp :D
You can pop off the ciggy lighter mate by lifting up the panel it's on, it just pops up
check to see if the wire is connected underneath
heaters is a strange one as mine had never gone wrong...
You sure the fuse is ok? if it's just a blade fuse behind the glovebox might be worth while replacing it if it's only 20p for a new one
Durham RSOC member
hello mate the heating problem is a common fault as ive done loads of them at work! if u look under the boonet near the wiper motor there is a valve in 1 of the heater pipes going in to the heater matrix with a plug on ( two wires ) that valve will hav stopt workin but its a easy job to do and only 20 summit quid from ford plus vat! hope this helps!
OCD Victim
vdun01
Ford Fiesta
05-10-2017 08:14 AM
