Rear bush
Old Oct 10, 2008 | 03:10 PM
muffster's Avatar
muffster
Default Rear bush
Hello fellas.
My sapph cos has failed the MOT today on a rear swing arm mounting bush. Does anyone know where i can get hold of one as they seem to be like the preverbial rocking horse shit?
Also what are they like to get out as it looks like a bit of a b####d to do, has anyone done one before.
Thanks,
Muffster.
Old Oct 10, 2008 | 05:53 PM
There are stack loads of poly ones for this location, after things are loosened you can do the bushes without taking arm off, but levering to one side.
Old Oct 10, 2008 | 08:47 PM
muffster's Avatar
muffster
Smile rear bush.
Thanks Tabetha.
Whats the easiest way to get them out?
Thanks.
Muffster.
Old Oct 11, 2008 | 06:56 AM
Depends on whether you have the rose joints(bearings) as some were supposed to have had to start with, these will need a fair tap to get them out or better a puller, or nout/bolt socket.
If polly though just opush out centre metal sleeve and they just pop out easy then.
Old Oct 11, 2008 | 09:57 PM
gaz4x4cos's Avatar
gaz4x4cos
mine failed on these , i went for poly bush and they seem good,but there are some proper type on ebay i have noticed since i got mine , pricey tho think they are 160 per side from memory . the garage that did mine had to burn the old ones out and they were a complete pig to do .
these got done and new koni shocks and drives so much beter through bends now .
cheers
gaz
Old Oct 12, 2008 | 02:49 AM
Reid's Avatar
Reid
these rear bushes piss me off in work lol. burning gear comes out right away!
Old Oct 16, 2008 | 10:33 AM
muffster's Avatar
muffster
Thumbs up rear bush.
Thanks for the replys guys.
Looking underneath does the rear axle mounting plate have to come out first to ge tot the semi trailing arm?
Thanks a lot.
Muffster
rex647
Mar 6, 2022 06:20 AM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
