turbo and n/a piston rings different?
Old Sep 20, 2008 | 06:18 PM
Reid's Avatar
Reid
Default turbo and n/a piston rings different?
as above, are the RS Turbo and std 1.6 cvh piston rings different? ive had a quick look and cant even find the piston sizes to see if theyre even the same diameter.
cheers.
Old Sep 20, 2008 | 06:22 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I do believe turbo rings in general to be different to n/a type. IIRC its something to do with the tolerances on the rings and their cutouts in the actual piston but please on't quote me.
Ford will have the part numbers on their computers st the service desk...ask them to pull you up the numbers for rst and n/a rings....might even be available still????
Dan
Old Sep 20, 2008 | 06:24 PM
Reid's Avatar
Reid
Dan
Ford dont have a good track record with my phonecalls. especially when i phoned the last time and had some little fud tell me the RS Turbo was a cosworth.
But i'll try again on monday!
Old Sep 20, 2008 | 07:23 PM
SillyFezzaMk1
Rubber Rhino Crew
go in mate, when you go in take a car reg for both....a reg for a known rst (on V5 too ) and a known n/a model....they'll be a lot more helpful then...
In my experience you're MUCH better off nipping in if you can...that way you can explain to them and show them what you're after on their screen pictures.
Dan
Rstar_man
143
Jul 20, 2020 11:16 PM
Matt Baxter
Sep 16, 2015 08:30 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Escortdriver1
Aug 31, 2015 11:19 AM
Adam-M
22
Aug 10, 2015 10:46 AM
