mechanical abs
Old Sep 18, 2008 | 06:19 PM
rudkinrst's Avatar
rudkinrst
Default mechanical abs
hello people, i was just wondering on how to go about taking the abs system off my escort rs turbo, ive got a master cylinder off a 1.6 sierra. it has only 3 outlets. wud this be substantial. iyt means i wud have to split the outlets to the rear is that ok???
cheers
chris
Old Sep 19, 2008 | 04:34 AM
stevecossy's Avatar
stevecossy
Hi mate, I would just change the resvoir (spelling) to a 2 outlet.
The abs pumps are a bit of a twat to get off but with a bit of brute force and an angle ginder they come.
Some people just tie wrap the sensors and others put a loop wire in.
Then ya need to loop the brake pipes together in the blocks under the floor at the front, just remember which went to which.
Im sure all will be clear when ya start the job.
After its all removed another bonus is its a piece of piss to do a clutch change with all that shite out the way.
Good luck. cheers steve
Old Sep 19, 2008 | 11:43 AM
rudkinrst's Avatar
rudkinrst
thanks mate my earbox is out anyway cos the lsd has collapsed
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
