whats up?
Old Aug 31, 2008 | 04:17 AM
Maximum Hustler's Avatar
Maximum Hustler
Default whats up?
just bought a mk5 cab with a 1.6 cvh turbo engine running cossie management.
2 of my friends went to pick it up for me and on the way back they said it just seemed like there was no power. the turbo was spooling up. the boost hoses were all fitted correctly and every thing looks okay but it started to over heat and they said it was like the engine was trying to hard hence the over heating.
has anyone got a clue what could be causing this?? broken sensor? bad wiring? mechanical?
any help would be great.
thanks neil (using maximum hustlers log in)
Old Aug 31, 2008 | 07:32 AM
notroubleclubber's Avatar
notroubleclubber
Back In The RS Game!
Sounds similar to my rs. Having the bodywork sorted b4 looking into the engine.
Old Aug 31, 2008 | 09:35 AM
LHD220Turbo's Avatar
LHD220Turbo
could be a whole host of things; air leak, weak actuator, perhaps take it to someone who knows a bit more
Old Aug 31, 2008 | 11:10 AM
Maximum Hustler
cheeRS guys
Old Aug 31, 2008 | 07:47 PM
project rs's Avatar
project rs
first thing i'd be looking at is head gasket, there's a liquid you put in water and if any exhaust gases are present then it changes colour as an indication as sounds like you might have a weaping gasket. Next on list is make sure all the fueling and timings are ok as these will cause it to over heat and lack power.
Old Aug 31, 2008 | 08:06 PM
Maximum Hustler
THANKS....
think i need to book it in somewhere and let the pros look at it.
cheeRS for the advise
Old Aug 31, 2008 | 09:26 PM
s1cab's Avatar
s1cab
got any pics of the car?? are u anywhere near london?? coz jano's the man for cossie managment round here !
Old Sep 1, 2008 | 02:24 PM
orion88's Avatar
orion88
if ur runnin cozy mangement on a standard actuator it wont fare well get a mins 31 on it or turn the boost down see if that helps
Old Sep 2, 2008 | 11:08 AM
Maximum Hustler
I got it from kent the other day but i'm up in blackpool so oddkidd's a bit out of my way plus motorsport development's about a ten min drive away.
i think oddkidd did the conversion to begin with and he mapped it at 210bhp but after it was mapped the previous owner left it stood for about 9 months and while it was stood he changed the dizzy to coil pack so this might have something to do with it??
Boot is set about 7 psi and its got a -31 on
cheeRS for the advise guys
Old Sep 2, 2008 | 11:33 AM
C534CDB's Avatar
C534CDB
You have pm mate
