Relocating brake pipes
Old Aug 29, 2008 | 01:04 PM
mentalasanything's Avatar
mentalasanything
Default Relocating brake pipes
Gents,
I am planning on re-plumbing the brakes on my ERST. I plan to run the front brakes from one outlet on the Master Cylinder and the rear brakes from the second. I then want to run the rear brake pipe through the inside of the car from front to back so I can connect an in-line bias valve adjustable from inside the car.
Will it still pass an MOT if the lines are inside?
What's the best way of going about it?
Many thanks!
Lee
stephenb4506
33
Oct 2, 2015 06:25 PM
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
