Car is acting funny after headgasketchange. Red manifold and turbo. no power *SORTED*
Old 25-08-2008 | 05:24 PM
Kverna's Avatar
Kverna
Virgin-popper
Default Car is acting funny after headgasketchange. Red manifold and turbo. no power *SORTED*
Hi.
I changed the headgasket on my sierra, and when I tried to drive it up our parkinglot it would bearly move. Had to rev it like hell and use the clutch plenty.
When I drove it to work, thinking it was just symptoms of cold plugs and cold engine, it held back and wouldn't rev. Could hardly come over 3500rpm, and when I came home the manifold and turbo glowed bright red.
It also pops and bangs when I use enginebrake
I have checked almost everything I can think of, but can the cam be 180degrees wrong, and even be perfect idle ?
It's a 2.0L Pinto is-engine
All help is highly welcome
Old 25-08-2008 | 06:42 PM
rapidcossie's Avatar
rapidcossie
timing is out.
Old 25-08-2008 | 06:45 PM
Defo timing is out, way out, ignition timing that is.
Old 25-08-2008 | 06:47 PM
cossie604's Avatar
cossie604
You've got a sausage, probably Walls as they're thicker, stuck in the tail pipe. A common probelm thats often over looked.
Old 25-08-2008 | 10:31 PM
Kverna's Avatar
Kverna
Virgin-popper
So should I turn the cam 180degrees, or turn the distributer ?
Old 25-08-2008 | 10:35 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
check all the timeing marks are in the right on the timing belt easy to get to if i rember rightly. and also get your self a timing light. but you shouldent have tutched the dissy doing the head gasket so more likley to be the belt side of things.
Old 25-08-2008 | 10:38 PM
stucapri2.9iTT's Avatar
stucapri2.9iTT
hi mate
have you checked the firing order
stu
Old 25-08-2008 | 10:41 PM
Kverna's Avatar
Kverna
Virgin-popper
Should be correct, but can be 180degrees wrong, someone told me. We took everything out to change it, cause it haven't got served in a long time
Originally Posted by stucapri2.9iTT
hi mate
stu
1342 right ?
Old 30-08-2008 | 07:24 AM
Kverna's Avatar
Kverna
Virgin-popper
Thank you all. I turned the cam 180 degrees around, and the car runs smoother than a baby's butt. Will have it adjusted and dynoed today
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 08:45 AM
track.focus'd
12-08-2015 06:53 PM
rsstav
Ford Focus ST Parts for Sale
11-08-2015 05:19 AM
marvin
Fiesta RS1800/RS Turbo
11-08-2015 12:14 AM
blakey100
04-08-2015 09:17 PM
Quick Reply: Car is acting funny after headgasketchange. Red manifold and turbo. no power *SORTED*
