4x4 sap motor swap tdc sensor problem
Old Aug 24, 2008 | 10:38 PM
cossie4x4's Avatar
cossie4x4
Default 4x4 sap motor swap tdc sensor problem
hello I have a problem with my tdc sensor bracket.
I have a new engine and i used the pully's from my old engine.
the mounting place is to close to the crank pully. so the tdc sensor won't fit
i don't want to swap de old sump , cos i have to get the engine out again.
is there a other solution.
see pics
new engine
new engine
old engine
the bracket
Old Aug 24, 2008 | 10:55 PM
The DIVA's Avatar
The DIVA
The only thing you can do is to space the sensor from the bracket to get the correct clearance.....
I have had to do this once in the past as an emergency measure and i made up some spacers in the lathe to move the sensor away from the bracket.
Old Aug 25, 2008 | 07:10 AM
The easy way is just get some longer bolts and some nuts that are slightly bigger so they fit over the bolt and space away.
I therefore assume there are different size pulleys on the 4wd ?
Old Aug 26, 2008 | 08:11 PM
cosworth3d's Avatar
cosworth3d
It had a 2WD belt setup but the wish is to use the multi flat belt and yes the 2wd crank pulley is smaller than the 4wd one !!!
manuel boeckx
13
Oct 3, 2015 02:29 PM
jdsjojo
PassionFord Swap Shop.
Aug 26, 2015 09:51 PM
Shows & Track Days
Aug 15, 2015 06:25 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
