burning oil
Old Nov 6, 2004 | 12:39 PM
Big_Daz_206's Avatar
Big_Daz_206
Default burning oil
i have a g reg bog standard 2wd sapphire cossie which has only done 90000 on the clock and has only done 9000 miles in the past 3yrs, i bought it a month age and now it is using alot of oil, i have no leaks and it boosts ok. if any1 has any advice thats would help, i would be very grateful
Old Nov 6, 2004 | 12:46 PM
rapidcossie's Avatar
rapidcossie
all cossies burn oil. if its burning lots then something will be wrong in your engine i.e rings etc?
Old Nov 8, 2004 | 08:51 AM
saphcosworth's Avatar
saphcosworth
The book says they are suposed to use around a litre of oil every 600 mile
Old Nov 9, 2004 | 02:59 PM
Dave Henshall's Avatar
Dave Henshall
as above - upto 1 lite of oil per 600 miles is normal - and thats when new
open your airbox lid and see if the brerather is chucking loads of oil back up the pipes into the airbox - you couls help matters by fitted a decent breather system, but as aboive also, if its got excessive blowby on the rings, you really need to get that sorted with a rebuild, but if u are not too bothered and just want it to run till it dies, geta breather system fitted.
Rsmat
89
Oct 12, 2015 07:50 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
