Dif between Focus RS headgasket + .....
Old Aug 17, 2008 | 05:33 PM
MJ_RST's Avatar
MJ_RST
Default Dif between Focus RS headgasket + .....
Just wondering if anyone has used a focus rs headgasket on their zetec turbo conversion??
are there any differences between the gaskets that would prevent it from being used??
cheers
Old Aug 17, 2008 | 05:35 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
If I remember correctly, the Focus RS HG is the same as a normal 2L zetec, at 0.7mm thick.. The ST170 one, is apparently 1.0mm thick. Apparently, perhaps.
Old Aug 17, 2008 | 05:42 PM
MJ_RST's Avatar
MJ_RST
Ahh ok, do the gaskets differ between blacktop and silvertop then??
Old Aug 17, 2008 | 05:52 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Don't believe so..
Old Aug 18, 2008 | 11:45 AM
JesseT's Avatar
JesseT
Focus RS gasket is the same as any other 2.0 blacktop gasket (3-layer) at ~0.6mm apart from the ST170 gasket which has a thick 4th layer and thus totals to around 1.0mm. The silver top gaskets are not metal multilayer gaskets and are by no way as thin as the newer blacktop gaskets.
Old Aug 18, 2008 | 01:39 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
JesseT- are you sure that applies to the 2L silver top? I've seen 1.6 and 1.8 early engines with the composite gaskets, but never on a 2L.
Old Aug 18, 2008 | 06:47 PM
MJ_RST's Avatar
MJ_RST
So for use on a zetec turbo, which OE for gasket is better for a silvertop engine?? the ST170 one??
Old Aug 18, 2008 | 06:56 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Depends on what you're trying to achieve.
Old Aug 18, 2008 | 08:11 PM
JesseT's Avatar
JesseT
Depends for which gasket thickness your bottom end is built for.
pa sjo: Can't be 100% sure. Mine came with one when I opened it, but I can't remember if it was a Ford original gasket.
Old Aug 19, 2008 | 06:55 PM
MJ_RST's Avatar
MJ_RST
Well im thinking of going the c20 let route failing that il be using area six items
Old Aug 19, 2008 | 06:59 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Well then you have no clearance issues
If you're going for 300bhp or less, i'm sure the CR you get with the 0.7mm gasket would be fine with those pistons.
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
